big joe help again sorry
RE: big joe help again sorry
freez hows the .26 in the revo just out of sheer curiosity not that u would bend my arm and make me get one "hint hint"
is youor vid the revo in the snow cause in that vid even in the snow it was showing loads off torque is it just a straight drop in with new eng9ne mounts
explain if you will please cause u got me very intrested im not worried about working on my car or breaking anything so fire away
MS
welp I would say get the stage 3 kit here http://www.qoncepts.com/RCpages/TraxxasRevoRBBC.htm
they exlplain on there website what you will need in addition to there kit . I say the stage 3 because it gives you the 3 show flywheel , you are going to be upgrading to a big block , and you should upgrade a few things , HPI 18T clutch bell , ofna alluminum shoes , shim kit for the clutch , just in case you need a couple washers , i use the stock spur gear , you could go to a 36T , keeps the wheelis down , I chose the HPI ribbed pipe , but that is of your choosing ( you want an 1/8 style pipe ) Pull start engine ,you may need to change a-arm for clearance , not to sure on that one , I have a starter box from RD so didnt have to go there , well this is what I can think of off the top of my head , you may want to change to the FOC kit , it is a recommendation but your choice . If I can think of anything more , will let ya know , lol , it is pretty easy to install , just a little bit more than just ( drop in ) worth it in my opiniun
so u using the stock plastic gears from the FOC and they haven't stripped???
can you please give a link to one of your vids???
MS
FOC kit has been great with the BB , and here is a link to one of my vids
http://www.rcpics.net/img/45373
make sure after you push this link to right click and save
