Somethin' Extra CG
My Feedback: (-1)
Somethin' Extra CG
I'm running a SIG Something Extra with an O.S. 50 SX and I'm contemplating how to move the battery pack behind the fuselage for CG purposes. It's either move the pack or add weight to the rear. Keep in mind that this is to put the CG at beginner-based spot according to the instructions. For maneuverability, I would even have to go farther back. I've already installed the servos and would rather not take them back out, so would it be such a terrible idea to cut a rectangular hole in the rear fuselage, insert the battery then repair. Even if I do decide to remove the servos for underneath clearance, I can't reach under the servo tray enough to get to the back of the fuselage to mount the battery. Any ideas? Also, the plane hasn't been off the ground yet and this is my first non-trainer - any suggestions as to what to expect, etc. would be really cool. Thanks
ON, CANADA
RE: Somethin' Extra CG
It is very unlikely that you need to move your battery back.
The CG has to be right on the middle of wing tube.
For first flight I would recommend low rates (even 70-80% of low rates as per manual on ailerons) and 30 % expo on everything.
I don’t think it is a good second plane despite that many people here do recommend this plane as second one. It flies not bad and lands itself (but it will not teach you how to lend), you will have to fly it all the time and make small corrections continuously through every maneuver, in particular - in windy conditions.
It is small so don’t fly it too far.
And to find a friend who will trim it for you is a MUST.
