Balancing props
Balancing props
Hello.
I've just check that my news Menz S wood props are not balanced with a balance tool. How should I balance them? Sanding, scraping, with spray laque...?
I've never balanced a prop, so any advice would be great
Thank you very much
Thank you very much
RE: Balancing props
I only have one Menz. Most props that I balance I scrape the front of the heavy blade. But I wouldn't do it this way on the Menz. The Menz is just too nice a prop to have one blade scraped up. For the Menz I would get some spray clear lacker and spray the whole prop with a light coat to get the color the same and then hit the light blade with a few extra coats to get it balanced.
hope this helps
tonyc
hope this helps
tonyc
My Feedback: (10)
RE: Balancing props
Check out this site: http://www.aircraftinternational.com/ There is a great video on how to balance props.
RE: Balancing props
ORIGINAL: Nogyro
Thanks for the link.
AB, CANADA
RE: Balancing props
On single cylinder gas engines,put the piston at top dead centre and place the heavy blade opposite it at the bottom. I found this worked better than distorting the prop by sanding or adding paint.
Moderator
My Feedback: (58)
RE: Balancing props
Nice video! Allow me to digress a little: Has anyone tried this prop balancer http://www.amelung-modellbau.de/index.html?lang=en-us ? Just curious if it works well........
My Feedback: (10)
RE: Balancing props
ORIGINAL: bigguyplanes
