SS throttle
NY
SS throttle
The stock throttle linkage on my SS seems to be too tight so that when I go to full brake and return it to idle the throttle opens up a little bit and it moves while idling. Loosening up the screw on the servo seems to help but not very much. Is this a common problem? Is there anything I can do to solve this? I saw the Ofna Throttle linkage mod on this forum somewhere. Would that fix the problem? If so, how much would that cost?
NJ
RE: SS throttle
idk if it will fix your problem, but try adjusting you servo position, and then lengthen the linkage going from the swivel arm to the carb.
RE: SS throttle
You need to adjust the Throttle servo saver so that it's keeping the carb closed. The next problem your going to find is that your throttle won't open all the way, thanks to an overly strong return spring and a very weak spring in the servo saver.
I fixed this by removing the return spring. You HAVE TO HAVE A FAIL-SAFE if you do that though.
RE: SS throttle
I was having the some problems with my link age set up Dave33 very kindly posted all the parts requires for the throttle mod see links below
Dave33 I hope you dont mind I posted your pictures below of your linkage set up
Dave maybe you should do a step by step guide on making up the linkage ?????????????????????
http://www2.towerhobbies.com/cgi-bin...8&I=LXBL85&P=K
http://www2.towerhobbies.com/cgi-bin...8&I=LXK077&P=K
http://www2.towerhobbies.com/cgi-bin...8&I=LXFRR1&P=K
http://www2.towerhobbies.com/cgi-bin...8&I=LXK064&P=K
http://www2.towerhobbies.com/cgi-bin...?&I=LXFV04&P=7
http://www2.towerhobbies.com/cgi-bin...&I=LXK014&P=ML
http://www2.towerhobbies.com/cgi-bin...?&I=LXD832&P=7
RE: SS throttle
http://www.rcuniverse.com/forum/m_25...tm.htm#2565421
This is a link to a how to throttle brake link mod that I did hope it helps. It is pretty detailed
