fiberglass putty
hey guys i formed a fiberglass cowl for my airplane and was wondering if anyone knew of some kind of putty that is easy to sand to form and will adhere to fiberglass. it got to be form either tower or hobby people though. thanks
Hi Bryan,
I used "spray putty" from a paint supply store to finish my cowl. It worked very well and sand very easily. I know its' not from the store you nominated but any paint supply shop should have it.
Cheers,
Colin
Cheers,
Colin
My Feedback: (21)
From Tower Hobbies....
#1. item # TOPR1090....Supreme micro balloon filer.
#2. item # GPMR6165....Milled fiberglass.
Either one will work....mix with fiberglass resin, then put in the catalyst. Mix
again, and apply. The micro ballons are lighter. There is another product
called "cabosil"....it is very light, and makes a good puddy too....available
where ever fiberglass products are sold.
FBD.
FBD.
I use Ever-coat fiberglass bondo. Stays semi flexible. Has a pretty short work time, I think around 10 minutes or so, mix small quantities. Cure time to sanding is less than an hour and sands like hard balsa when you use 80 grit aluminum oxide sand paper on a sanding bar. I've only used it once but will definately use it again. Got it at an auto parts store.
Edwin
Edwin
