Rebuild of Kadet St.
OK
I damaged the aft section of the fuselage on my Kadet Sr. Everything else is fine. The tail assembly is still in one piece, as is the bottom part of the fuselage. However, I will have to rebuild the frame work. I don't think I can put the puzzle back together. Should I buy a kit so I can have access to the plans, try to repair it, or would I be better off just building a whole new fuselage? Thanks. Jim
RE: Rebuild of Kadet St.
The fuselage particulary the rear half is nothing but sticks and sheet for the Kadet Senior. Looking at my kit the only diecut peices were the fire wall?, the landing gear mount and a couple formers over the tank. If you bought just the plans one would easily fabricate the fuselage.
Sig lists the plans for the Senior on the followingt page for just 10.50.
[link]http://www.sigmfg.com/cgi-bin/dpsmart.exe/MainMenuFV4.html?E+Sig[/link]
