Replacement needle valve retainer
Old 03-01-2005, 11:30 AM
sportflyer-RCU
My Feedback: (35)
Default Replacement needle valve retainer
Recently I had the misfortune of breaking the tab of the needle valve retainer clip in my Rossi 45. I was thinking of using a spring hose clip and soldering a piece of piano wire to it as a retainer but I cant find a small enough hose clip . Any ideas? Tks
Old 03-01-2005, 12:29 PM
Campy
Campy's Avatar
Default RE: Replacement needle valve retainer
Why not just get some replacement clips ? I recently got some from my LHS for spares (ordered ) and they were about $.25 each.
Old 03-02-2005, 06:50 PM
sportflyer-RCU
My Feedback: (35)
Unfortunately the clip might cost me $10 by the time I pay shipping and handling !
Old 03-02-2005, 07:39 PM
daveopam
My Feedback: (9)
daveopam's Avatar
I made one from a pocket clip off of a ball point pen. I found one at Wal*Mart that the clip slid on over the end. It might have been a mechanical pencil? Any way I was able to cut the clip shorter and bend a V into it. Works great. You might also try your idea with a Zip tie instead of a hose clamp.
David
Old 03-03-2005, 08:06 PM
sportflyer-RCU
My Feedback: (35)
Great idea !!! Tks
Old 03-03-2005, 10:28 PM
Gringo Flyer
My Feedback: (18)
Gringo Flyer's Avatar
I lost the clip on one of a .40 engine and I just replaced it with a metal wire. If you find one fine enough but pretty stiff, just take a pair of needle nose pliers wrap it around the base a few times and then bend an arc in it so that it touches the needle. It took me about 30 seconds to install and it works perfect and only required a piece of wire I found lying around.
Old 03-04-2005, 06:28 AM
woodbutcher
Stretch a piece of large fuel line over the assembly. Holds tight and seals the needle from air leaks.
Old 03-06-2005, 10:40 PM
jessiej
Woodbutcher's idea has worked for me. Has improved the run of some engines by forming a better air seal.
jess
