What adhesives do I use
NJ
I am in the process of building a cockpit for a P40. I will be using a variety of materials which need to be glued together. I will be using ply, balsa, styrene I have no idea of how to glue styrene to balsa or ply. Any suggestions would be appreciated
RE: What adhesives do I use
ORIGINAL: ifixairplanes
Isn't styrene styrofoam??? I've had goodluck melting styrofoam with medium CA!
Sean
Sean
Whatever the case, you are looking at a mechanical bond. If it were me, I'd use polyurethane glue after scuffing the styrene with 80 - 100 grit. CA might fog what you don't want fogged.
Thanks for the clarification deadeye.
BTW: Gorrilla glue is a type of polyurethane glue
Sean
Sean
