pipe savage what the best!
NJ
RE: pipe savage what the best!
i have the ribbed, great performance gains. Many people also like the Golden Horizons pipe. I bought mine because it was cheap, and i had heard good things about it on this forum.
PA
It depends on what you may be running in the future and what you want you stock engine to do. If you want killer low end go with a ribbed pipe. They are louder that other pipes and that may be a factor. If you want a good mix of power and speed go with the hot bodies pipe. The pipes that have three spings that hold them together instead of the silicon coupler are more expensive but they seal up better are alot quieter and can be used with alot more engines. THS makes a great savage pipe and Fantom"s steel pipe works great and they have pipes that give you low end or high end power you have to decide.
