Trans. Help!!(Stealth)
Ok Rebuilt trans. Everything went back where it was supposed to after cleaning & ck'ng. it out. Tightend diff. all the way & backed off around 1\8 turn, & slipper about 1\4. Will barely move!! Tried holding both wheels & spinnning spur gear...Turns fairly easily. While running & holding 1 wheel the other still turns. While off & turning 1 wheel the other turns the opposite direction. I know thats right. What am I missing here. Plus out of curiousity, how do you adjust the diff without taking trans. off every time. The dogbones are in the way unless I'm missing somthing. Which could be as I'm fairly new at nitros. O yea, It's an RC10GT. Any & all help appreciated
Thankx
Thankx
My Feedback: (158)
RE: Trans. Help!!(Stealth)
When you turn the spur you need to make sure the slipper slips before the diff does.
you look at the slipper plate while you are turning the gear to see which is slipping
To adjust the diff you take off the camber link on the spur gear side, then the dog bone will come out of the cup, make your adjustment and put it back together
p.s.,
When I adjust mine I hold the one wheel and the spur, while turning the opposite wheel
I find it easier to see whats slipping that way
p.s.,
