Clippard and Spring Airs
Old 03-15-2005, 03:52 PM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Default Clippard and Spring Airs
Hi guys,
I have a clippard 3-way, I assume normally closed valve for my Spring Airs. Problem is,when I presurize the air tank, there is an open port that leaks air gradually, and eventually loses all pressure (takes about 2 minutes). The port bleeds air in off and on position, however if I block the port the bleeding will stop, but it won't extend the landing gear.
Has my valve gone bad? Can I use a normal Robart valve and "jumper" the unused port?
David
Old 03-15-2005, 05:03 PM
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Default RE: Clippard and Spring Airs
Do you have the tubing connected to the correct ports? Are the ports labeled?
Old 03-15-2005, 05:13 PM
FalconWings
My Feedback: (57)
Well, I assume that the tubing is installed correctly, cause it does retract/extend correctly.
See the picture, it is the one on the left hand side (red button). The air in/out ports are underneath it. The port facing forward of the jet is the one that bleeds off air.
Thank you Mike
Old 03-15-2005, 05:26 PM
Todd Jackson
I will look at my valve when I get to the house and I think mine has onley 1 air in and out nipple..Todd
Old 03-15-2005, 05:30 PM
patf
patf's Avatar
the valve in question is a smav-3 clippard part. david i will pick up a spare for you this week.
Old 03-15-2005, 05:41 PM
FalconWings
My Feedback: (57)
Hey don't worry Pat, JT has a spare one so I can get the model ready for Waco. Just want to make sure that I get it in right.
I was able to fly again Sunday (with 25-35 winds), but 2 minutes after takeoff the landing gear extends, kind of like a built in timer.
BTW, how long can you fly that thing?. I fueled her up, flew for 7 minutes, landed and did not refuel, flew again for 5 minutes, landed and there was still enough fuel in the hopper for a couple of touch and go's.
Old 03-16-2005, 11:01 AM
patf
patf's Avatar
i would go for up to 8 minutes if i knew i could land whenever. at events i would set it for 6. it is not a tough plane to land dead stick. i will be in waco friday afternoon and saturday.
fwiw the end opening is the exhaust, and should only let air out when the button is released for a moment.
