OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
65" Yak 54 Wing kit
Old 05-04-2005, 01:19 PM
RJConnet
Default 65" Yak 54 Wing kit
When I buillt my Yak 54 I managed to build in a whole bunch of washout in the right wing by setting up the trailing edge shim backwards when I built the right wing. I have been flying it that way for a while using a lot of aileron offset but I know it is time to set it right. Is a wing kit available or better yet a right wing kit? I could even get by with a rib set including the ply root rib as I already have the plans and the shim and rib angle jig. All the other material is available locally. What can you do to help me?...........RJ
Old 05-04-2005, 07:52 PM
IowaSilvia
My Feedback: (97)
Default RE: 65" Yak 54 Wing kit
I almost did the same but caught myself. I did however put the number 4 rib upside down on the left wing. So the 2 cutouts for the servo rails were on the wrong side. So I had to put an oval back in the lightning hole and cut out 2 new notches for the rails. I told myself 50 times not to forget that the notches go down on the left wing.. sheheeshshshshshsh..........
Old 05-05-2005, 09:48 AM
AFSalmon
AFSalmon's Avatar
You bet, would you like some bbq sauce with those spare ribs? ha ha. Just drop me an email at the website and tell me exactly what you need and I can get it to you. I can do just ribs or a whole wing kit, either way.
