Radiowave 40% Edge
My Feedback: (56)
Radiowave 40% Edge
I'm looking for info on the Radiowave Edge- flight performance, weight,
quality ect... Its been out for a while and haven't read anything about it.
Thanks! chris
Thanks! chris
RE: Radiowave 40% Edge
Hi Chris, We have a gentleman flying IMAC in the NorthWest region and he had to do quite a bit of modification to get it to fly the way he wanted. I don't own one, so I can't give you any first hand info but like any purchase I would investigate it very carefully!
Good Luck, Jim
Good Luck, Jim
If I'm not mistaken that fella in the Northwest is Ron Smith and I'm the one who modified his Radiowave (JTec) Edge. As it sat with 2 rudder servos in the tail it was 5lbs light in the nose to balance.
1. Went to a pull-pull rudder setup.
2. Threw the horizontal stab away and replaced with a Aeroworks 40% Edge Stab.
3. Cored Elevators.
4. Cored Rudder.
5. Cored out underbelly of fuse.
6. Put on heavier wheels.
7. Moved everything as far forward as possible.
The plane is now just on the rear side of the CG but it flies extremely well. We were both very happy about flight performance.
The covering job and material is very bad, no horrible is a better description. Much of it has flown of the plane in flight. The paint is over the bare fiberglass without priimer so it chips off extremely easily. The cowl is very thin and is wavy in spots because of it.
This was one of the original Edges out of South America and apparently Al Young is now importing them from China so the quality issues I've noted above may not apply. I do know that Al Young wants to scrap the horizontal stab and go with the tapered one like the full scale Edge. Maybe he has already done it.
Rich Sornborger
IMAC2335
3. Cored Elevators.
4. Cored Rudder.
Rich Sornborger
IMAC2335
