HS 5735MG is not running real smooth??
Old 06-10-2005, 09:59 AM
Steve
My Feedback: (54)
Steve's Avatar
Default HS 5735MG is not running real smooth??
I just test ran a new HS 5735 on the rudder of a Colombo Anderson 31% 300L and am a little worried about its transitioning. I use several 5645's and they run pretty smooth. The 5735 seems to jump slightly when I move the stick very slow. Is this common for this big servo? I bench ran the servo for 20 minutes last night with the programmer and it got a little warm, but not hot by any means, and worked ok. Any one using these please help. Thanks.
Steve
Old 06-10-2005, 07:30 PM
Diablo-RCU
Default RE: HS 5735MG is not running real smooth??
I've been running a 5735 on a Wildhare 35% Extra rudder with pull pull. Smooth and no issues with gear wear - about 500 flights on the servo. Check to make sure you have programmed the dead band to as low a number as possible.
