Trimming questions
My Feedback: (17)
QC, CANADA
Trimming questions
My 28% Edge does not keep its track on the downlines after a stall turn with rudder at full deflection and throttle at idle. The plane pulls to the canopy.
1) Should I programm a mix rudder to elevator or throttle to elevator in the TX?
2) The stab incidence is 0.5 degres.
Daniel
Daniel
My Feedback: (17)
QC, CANADA
RE: Trimming questions
MY CG is where i need very little down elevator on inverted flight. I am going to try throttle-elevator mix with a switch to test it.
Daniel
Daniel
My Feedback: (45)
Start over completely with the trimming of your model. Use Peter Goldsmith's trimming article in the Scale Aerobatics section of Feb and Apr Model Aviation magazing. There's even an article condensed version here on RCU if you search for it by typing in "Peter Goldsmith" in the search line.
Good luck...the mixes all come at the end...
