Gear door hinge installation?
Old 07-18-2005, 06:48 PM
wsmalley
Default Gear door hinge installation?
O.K., I feel like a real dumb a--, but how do you install gear door hinges? I bought some of these nylon hinges, which I think are worthless. I made a nose gear door with a lip and tried fitting these nylon things. After damn near ruining my door, I've decided they are not 'deep' enough or something. Seems like no matter which way I move them, the door won't open. The door is about 2" wide and 7" long with a raised part inside and about a 1/8th lip around the outside. Seems like there must be some rule of thumb here or you'd tear up your doors tack gluing 10 times. Signed, Frustrated in TN!
Old 07-18-2005, 06:57 PM
the-plumber
Default RE: Gear door hinge installation?
If you're talking about something like the Robart #350 door hinge found at http://www.robart.com/Hinge.aspx (scroll down the page), you need to get the correct 'scale', or make your own.
'course, it might help if we knew what model . . .
Old 07-18-2005, 07:43 PM
wsmalley
Yep! Like the Robarts. Here is a pic with one of the nylon, and one I roughed out. Can't seem to get the geometry right. BTW, it's a Su-27.
Old 07-19-2005, 02:43 AM
The Ghost
The Ghost's Avatar
wsmalley,
To get the hinges to work properly the hinge line has to be on the split line of the gear door. In the photo it is about 1/16" off.
Cheers
Old 07-19-2005, 07:34 AM
HalH
My Feedback: (12)
If you have installed them like the picture, they are backwards. The small part goes on the fuselage and the large part on the door.
Old 07-19-2005, 07:16 PM
wsmalley
Think I got it. The balsa represents the fuse and the little piece will be a 'stringer' between bulkheads. The 'U' needs a little more grinding to allow the door to swing completely down. The gap between the door and 'fuse' can be slightly smaller to allow the door to open. There are probably other ways of doing this.
ID:	299242   Click image for larger version
ID:	299243   Click image for larger version
