for you electric wizzes
NY
Hey guys, I am redoing my flied box, and was wondering if you can help. I would like to have one switch that can turn on and off all the power. It has lights and more switchs please study the diagram, please tell me if its correct. When you fly a switch to on the light should go on saying that there is power for the tool( glow starter, starter, pump)
here it is
if u guys want to make any changes here is the blank version
here it is
RE: for you electric wizzes
Cliff,
This way may be simpler. Run a ground wire to each LED and to each unit,( Glow, Starter,Pump), from the battery. Fuse a single positive lead to main switch, in on position it powers it's LED and applies power to other switches, As each switch in line has power to it, as soon as it's turned on it powers it's grounded LED and load.
AZ
Cliff:
Just looking at your diagram - it's flawed! Turn any switch ON and you've shorted out the battery.
Give me a minute and I'll sketch up your wiring diagram.
feihu
feihu
AZ
Cliff:
Here is your wiring diagram.
Please note that the switches can be SPST and only red wires go to the switch.
The switches should be able to carry the necessary currents.
The pilot lights are 12v lights.
I assume the 12v GLO goes to a 1.5v glow driver circuit.
Good luck
feihu
Good luck
feihu
