Activating P-MIX switches on Futaba 9 CAP?
My Feedback: (7)
RE: Activating P-MIX switches on Futaba 9 CAP?
Press mode/page and you are in basic (acro)
Press mode/page again and you are in advance (acro)
Press rota. knob once for P.mix1 and you are in P.mix1
press select (cursor) down twice and you are on the second page for the P.mix1 on mix>INH
Turn rota. know to left one click to get the P.mix ON
Tara, you are done.
CARS II
PS: I hate computers, I think they hate me back, so we are even.
Tara, you are done.
CARS II
My Feedback: (24)
You'll also want to get the Anne Marie Cross book. It shows you how to get to the hidden screen which allows you to reverse the throttle trim to work at the low setting after reversing the throttle channel and things like that. Found that little tid bit after fighting the set up of an FTE 500, then ending up mixing a switch into the throttle channel (wish Futaba had told me). While Futaba's documentation has improved, it sure has a long way to go. The Anne Marie book is MUCH better and worth the little money it cost. Much better reading.
It's not a bad radio - I've enjoyed mine so far and it has exhibited outstanding range to-date.
