Dragonfly #4 flight sim
Hi
Ive installed the free flight sim i got with my dragonfly #4, Ive only used it once because the next time i came to use it the dam heli wouldn't take off it just sits on the floor even at full throttle. Does anyone know where i could get a replacement free sim or how to fix the one i have. I would rather have a different one that has a helis of a similar spec and characteristics as my dragonfly #4.
Dan
Dan
I found ppjoy and installed it but it hasnt got the ppjoyCOM shortcut so i cant configure it for my tx. it also has several other icons missing.
ON, CANADA
Did you install the whole PPJoy program, or just the PPJoy drivers? There's two different sets. PPJoyCOM should be under the PPJoy menu under your windows start bar if you've installed it correctly.
It isnt it only has 3 links under PPjoy in the programs menu. perhaps the program i downloaded wasnt compleat. ill try again
MI
I had the same problem with my simulator. Just go up to the file menu and click on "select helicopter" or whatever it says. Different helicopters have different characteristics and won't fly. If you find the correct one it'll work just fine.
My Feedback: (10)
Also, on some planes, you need to hit "I" for initiate as soon as the new plane or helo comes up. I also downloaded an EP Concept which is a good model to practice with. I'm still learning on my #4 as well. If you have the PPJoycom icon in the PPJoy folder, copy that to your desktop and then click on it. When the window comes up go down to the pull down menu and find the Zean Hua(sp) protocol. Then click on your transmitter and the window should say "reading stream" Minimize the window but don't close it and you are GTG. When your installing the PPJoy, be sure to create your virtual joystick. Also make sure you get a good calibration before you start flying. Good luck
Anyone know if the PPjoy has copy rights protected? Why there is not formal website for the PPjoy download?
If the PPjoy is not copy rights protected, may be I can upload to my website for people to download it for free, as I have a lot of bandwidth and I should be able to provide that as free in [link=http://www.4-rc-helicopter.com]my personal website [/link].
