On Board glow starter
My first 40 size plane with inverted 2 stroke with cowl. It is difficult to get glow starter to bottom and then remove after the engine is started. Also possible dangerous to get hand so close to prop when it is turning.
What can be done about a simple on-board glow starter? It seems that a remote glow starter gets in the way of the rest of the electronics, servos, fuel tank. Can a on-board system work off the plane battery using a simple switch to turn it on and off? If so, would a higher capacity battery be required, or separate battery?
A step down for the voltage? The switch could be next to the switch for the plane.
Something simple like this would not weigh too much. What good systems are available?
RE: On Board glow starter
The simplest on-board glow driver for single cylinder engines is a switch and a NiCd battery. If you only use the on-board for starting it will last all day.
My Feedback: (23)
Here is a link to help you out. I have used this system on a couple of planes where I have an inverted 4 stroke, works great. The fellow who has the web page belongs to the same R/C club as me and is a good friend.
http://www.spieringswi.com/onboardglow/glow.htm
maddog
maddog
Thanks, these ideas are very useful. I guess with this system you would need to also buy a battery charger?
The heavy C size battery will certainly foul up the CG on my plane. This would take some adjustment.
But, that can be done. When complete it would be safer then reaching under the plane so close to prop.
My Feedback: (51)
go to c-tronics they sell a system complete w/ btty and all for around $70 i beleive
http://www.c-tronicsinc.com/
i have one i might sell i thought i needed it but got my 180 tuned and it is fine w/o
marty
marty
If your engine idles OK without the battery on the glow plug, just wire a remote connection for an external battery. Install the socket back near the LE at a handy spot, plug in the battery, start up, and remove the battery. You might need to go to a little hotter gloplug like a Thunderbolt or something similar.
A remote is an especially good idea on 4 strokes where the plug is hard to get to. Enya 4S have the plug on the front of the cylinder where it is almost impossible to get to with the engine running. They were shipped with a remote hookup. I have a model with an inverted Saito that you almost have to turn completely over to even see the plug. I'm glad you started the thread-I think I'll go put a remote on it.
Yea, I flew this morning. Had a geat time and plane did well. Each starting is just a discomfort connecting the glow starter and then inching the hand from the back on bottom of plane to remove it and not touch the prop. I was trying to get on-board glow installed last night but didn't have time to complete. Next week's flying it will be ready to go.
One of my flying buddies uses this MK unit-a little spendy, but if it holds up as well as he says it does, it might be worth it.
http://www.centralhobbies.com/glow/glowcap.html
VA
C-tronics fo for about $40 with battery. I use them on all my planes (6), not for reliable idle but to keep holes out of the cowl and my fingers away form the prop. You might be able to place the battery at the CG.
Carl
Carl
Dubro makes a unit that has a rotating cover.
The connection to the glow plug is easily put on with a needle nose pliers.
Here are a couple of pictures of the unit both inside and outside.
It allows you to use your current glow driver and can be placed anywhere on your fuse that youwant.
The cost is around 8-12 dollars.
http://www.shopatron.com/product/pro...d=DUB793/101.0
It is called a remote saftey ignitor part number 793 and 794
John
John
ORIGINAL: Geistware
Don't use the RX battery for the glow.
You will need to add another battery.
RX is 4.8 or 6.0 volts. Glow is 1.2 or 1.5 volts
6v rx battery... 4.5v resistor... 1.5v resultant voltage... resistor burns out.. who cares its already on the ground :-D (just dont wire it so its dependant on the starter having a compleate circuit... would require almost no rom at all you could even conenct the switch to the throttle servo when it hits max it turns on the circuit
I like the c-tronics unit as it is easy to set up. The problem I have is that the second time I hooked it up, the glow plug connector fell apart!
Balsa Master,Thanks. I am using a 4.8V Rx battery. If I use a 4.5v resistor the result will be as below. I am not familiar with using resistors and such. I don't know what problems it might cause with heat generated by reducing the voltage.
The problem I am having with the on-board C size is:
On my plane, the on-board glow igniter will not cold start my inverted 2 stroke Magnum 52. No matter how hot the C battery is.
Once the engine is started the normal way the C battery will start the engine, if warm.
The C battery measures 1.5V at battery, through the switch and up to the leads before connecting to glow plug and case.
Then when connected the voltage drops to .5 - .6 V across the plug to the engine case.
So, I think would need about 3 volts at the leads before touching the plug and case.
Whoa there big fella! Don't put 3 volts to your glow plug or it will be toast in very short order.
And, BTW all these comments about a 4.5v resistor??? Ain't no such animal.
Resistors are measured in OHMS.
The simplest on-board glow is a C cell wired through a switch. The next level is a C-cell
wired to a micro-switch tripped by the throttle servo horn. Like just above idle ON, 1/4 throttle and above OFF.
Then you can get the fancy stuff if you want.
Bumstead, thanks for the reply. I have tried to use the C size through a switch. Which is what I would first chose.
It did not work. See my message just before yours reply back to Balsa Master.
Rangerman, No solution yet. I was hoping to get something more simple than what those notes instruct.
I don't see any advantage to adding all the servo's, rechargeable batteries, charger, more work
when just a C size and two AA batteries and an external switch will not work.
It's really simple.
-you use a switch and a servo a mount it on a board and forget about it.
-you keep a spare AA battery with you
and that's it!
You can activate it by one of three ways:
-you can mount a small switch outside the plane (be creative and nobody will know it's there)
-activate it with a servo switch on you transmitter
-slave it to the throttle (remember to take the battery out or leave the engine throttle open.
I think for most people the easiest and coolest would be to use a transmitter switch.
and that's it!
Ok, I went back and read some of the comments. If your battery is falling to .3 v I think the battery is bad. I use a 1.2 v 1200 mah battery that comes with the rechargable battery set from Sams, Wal-Mart, Best Buy, Circuit City or who ever, and I get about 6 flights before I change the battery out. I don't know if the fact that I'm starting 4 strokes is part of the reason because I've heard that 2 strokes aren't good upside down but I was also told you have to run 4 strokes with a remote glow that is on during low power which is not true. I think the 2 stroke would flood the glow plug easier.
Rangerman, you missed my point. It doesen't matter how simple it might be. Nothing works on my plane.
No matter how fresh the battery is. Even using 2 AA batteries (2.4v). It just will not cold start the engine.
I don't know if it is an engine problem or something else.
