novak 5800 in tt01
BC, CANADA
novak 5800 in tt01
Can the tt01 handel the power of a brushless and if so, how long will the tt01 hold up? Sorry if this is a frequent question. Thx
RE: novak 5800 in tt01
why wouldn't it?? it might be a hot motor after running so get a good heat sink.and better gears so the motor wont strip the gears. i guess it'll work fine[sm=RAINFRO.gif]
Depends, few hop-ups necesarry. Aluminium Drive shaft,ball bearings, Low pinion or big spur but with the fixed motor mount that would be vry hard, and also I would recommend universals for smooth movement. The egar diff is probably fine, may even work better than the ball diff
