blade cp 4 n 1`
AZ
i have a blade cp thought that 4 n1 was fried cause light would not turn green....bought new one a still no green light...anyone have any insight...also anyone know the servo configuration on the blade cp like what channels go to what servo ..took so long to get the 4 n 1 i forgot what went where ...I never hooked up motors to speed control, and when i did with no battery connected light stayed red when i reconnected.......HELP
IL
punker1221,
When looking at the blade from the back (tail) this is the way the servo's should be connected.
Channel 1 – Right-hand rear “aileron” servo
Channel 2 – Forward “elevator” servo
Channel 6 – Left-hand rear “pitch” servo
As far as the motors. The tail motor hooks up to the top set of pins on the esc side, and the black wire should be next to the battery wires. Then main motor plugs into the bottom set pins on the esc side, with the black wire also facing the battery wires. If you have any other questions I will help the best I can. Good luck and hopefully everything works out for you.
Dan
Dan
