Aeroworks katana 36% comes in at 26lb 6oz
CO
Just a post on the Aeroworks Katana 36% ARF, I am putting together.
Finished up assembly and weighed it dry, 26lbs 6 oz. weighed with commercial scale accurate within +/-0.25oz.
Will weight 28lbs 6oz with fuel.
Plane has following,
DA100 engine with 4 custom engine stand offs and 26x10Menz prop-no spinner
7 hitec digital servos
2 2100mah lipos 3 cell receiver power + regulators 10 amp each
1 1900mah nicad ignition power
32 oz fuel tank
futaba 309 receiver
Will post pictures later when weather permits.
Tony
32 oz fuel tank
futaba 309 receiver
Tony
CO
RE: Aeroworks katana 36% comes in at 26lb 6oz
Servos are HS-5955TG and HS-5645MG. Budget is all I could spring for now.
It is a big power hog for the digital servos.
I am still deciding on a trim scheme for now.
I will fly it at the Boulder BAS field.
Tony
Tony
