Painting Aluminum Landing Gear
Old 11-12-2005, 11:59 AM
mrbigg
My Feedback: (21)
mrbigg's Avatar
Default Painting Aluminum Landing Gear
What do you guys use to scuff it up? I don't want to gouge the metal. The paint I'm using is Lusterkote white primer and metallic plum.
Old 11-12-2005, 03:10 PM
BBW Walt
BBW Walt's Avatar
Default RE: Painting Aluminum Landing Gear
I generally use a scotch brite pad. If the edges are rough, wet or dry sandpaper in a 220 grit will dress it up a bit. If using spray can paint as you mentioned I generally spray a coat of Zinc Oxide primer before paint. I get this from a local auto parts store that sell paint products. The can I have is made by TEMPO. It comes in a spray can, it sticks to aluminum extremely well and provides a surface for your typical spray can paint to stick to. Some paints will flake off if you flex the gear from a ruff landing, it just wont stick to the aluminum. This will not happen using a Zinc chromate or oxide primer....Walt
Old 11-12-2005, 04:37 PM
mrbigg
My Feedback: (21)
mrbigg's Avatar
Thanks, I'll go check out Autobone.
Old 11-14-2005, 09:40 PM
tinkicker
tinkicker's Avatar
ScotchBrite works good, then clean with denatured alcohol before painting. Works good
Old 11-15-2005, 08:14 PM
mrbigg
My Feedback: (21)
mrbigg's Avatar
thanks. i just want to avoid the paint flaking off.
Old 11-16-2005, 07:29 AM
pettit
My Feedback: (23)
pettit's Avatar
Use the thinner, cleaner or just hot soapy water BEFORE you rough the surface up.
If there is any oil on the aluminum and you scuff it up, it'll get buried deep in the scratches and keep the paint or primer from working well.
Then, clean it again after scuffing.
Old 11-16-2005, 09:02 PM
mrbigg
My Feedback: (21)
mrbigg's Avatar
will do, Dick. Thanks.
Old 11-24-2005, 12:32 PM
expo
My Feedback: (20)
expo's Avatar
Scanning this thread for ideas--I had one myself [img]
Has anyone ever tried covering aluminum gear legs with Monokote iron on or stick on trim to match the plane?
Old 11-24-2005, 02:13 PM
MinnFlyer
MinnFlyer's Avatar
It can be done, but painting is much easier
Old 11-24-2005, 02:30 PM
T. Bob
My Feedback: (9)
T. Bob's Avatar
I've done what Walt "No Glo"suggested last season on a 35%Wildhare Extra and flew it all summer without a flake or any kind of problem.
Thanks again Walt for the tip.
Old 11-25-2005, 02:04 AM
bipeflyr
Ive covered aluminum landing gear many times with Ultracoat, dont know how mono will do .
