3W-106 Prop for Break-In
Old 11-26-2005, 01:52 PM
PTS
My Feedback: (153)
Default 3W-106 Prop for Break-In
Hello!
Is the 26x10 3W 2 Blade Prop a good choice for the Break-In time on the 106?
Perry
Old 11-26-2005, 02:55 PM
flyinrazrback
My Feedback: (69)
flyinrazrback's Avatar
Default RE: 3W-106 Prop for Break-In
Its going to spin the snot out of that prop, get a 27x10 for break in and then a 28x10 afterwards.
Old 11-26-2005, 02:56 PM
Darrinc
I would use a 27x10, but I see you are probably at high altitude, and it seems in that situation guy are running a little smaller size and going for higher rpm.
Funny though, when the engine breaks in, you'll be able to spin a 26x10 3 blade!!!
Old 11-26-2005, 03:20 PM
flyinrazrback
My Feedback: (69)
Also, he is going to rip the 27x10 hard right out of the box.
Old 11-26-2005, 03:29 PM
bwick
We had a 28x10 Biela that was easy to rip on that engine...
26x10 wwaaaay too small, even for break-in.
Old 11-26-2005, 04:55 PM
flyinrazrback
My Feedback: (69)
PTS, are you running stock mufflers, cans or pipes?
Old 11-26-2005, 05:19 PM
PTS
My Feedback: (153)
I am running pipes. I do have a 28x10 Biela also...
Perry
Old 11-26-2005, 05:58 PM
Darrinc
On pipes! Use the 28x10!!!!!
But could you throw the 26x10 on and record the sound for us? That would be incredible!
Old 11-26-2005, 06:00 PM
flyinrazrback
My Feedback: (69)
You can probably get away with the 28x10 then since using pipes. For imac after broken in you will probably like a 29x10 mejzlik or fuchs best.
Old 11-26-2005, 10:41 PM
3D ONdaEDGE
It would be cool to hear a 26x10 at 8250 RPM.
Old 11-26-2005, 11:08 PM
flyinrazrback
My Feedback: (69)
3d, you want to hear cool? according to my 3w inflight tach, my 106 on stock mufflers 7900+ on a mejzlik 28x10 in the air and loud.
Old 11-27-2005, 06:30 AM
bob_nj
My Feedback: (62)
flyinrazrback --> Do you have the painted heads? Also, what were your inflight temps?
As far as props go, remember that most, if not all european props are shorter in inches than stated on the prop.
Some as much as .250" to .500" shorter.
Have a good weekend_bob
Old 11-27-2005, 12:59 PM
Darrinc
I was guessing more like 9000 rpm!
ORIGINAL: 3D ONdaEDGE
Old 11-27-2005, 03:57 PM
flyinrazrback
My Feedback: (69)
bob, not sure of inflight temps, I dont think the 3w tach does that, but wish , my motor listed above is a 106 SS, no painted heads.
Old 11-27-2005, 05:10 PM
3D ONdaEDGE
Is it louder than the 32x10 Prince prop on your 157?
Old 11-27-2005, 05:58 PM
bob_nj
My Feedback: (62)
Thanks...
Old 11-27-2005, 06:09 PM
flyinrazrback
My Feedback: (69)
3d, the mejzlik is loud due to the rpms, but not like a P tip, if you think the p tip on my 157 was loud, you should hear the 28x10 p tip on this 106, I bet it is 5x as loud as what you heard, and would honestly make you hold your ears, numerous people at the field complain.
Old 11-27-2005, 07:42 PM
3D ONdaEDGE
Thats it. Im gonna have to hear it to believe it.
