savage tires
savage tires
As new member to the MT scene,I have some questions about the savage 25. First off with the stock tire-rim setup,how much off-set do they have? And how much can you get for the truck to widen the stance. ( I have the truck coming thru Unlimited Parts Supply= UPS). So I havent seen it yet.Also If you go the really big tires like 7-8 inch range would they over stress the drive train? Thanks guys
VA
RE: savage tires
Stock savage wheels have no offset since they are after all,...stock!
But to answer your question,a set of pro-line 40 series wheels and tires are your best bet for increasing offset without adding a bunch of extra weight....Most all other wheel and tire manufactures seem to make their wheels and tires a bit on the heavy side,but Pro-Line however doesnt seem to have this problem....If your after looks aswell as off-set,then these are a good choise>
Best Looking Wheel> http://www2.towerhobbies.com/cgi-bin...&I=LXJVG0&P=ML
Best Basher Tire Ever> http://www2.towerhobbies.com/cgi-bin...&I=LXDCW1&P=ML
But with the Che rims you will need to buy the well worth it 23mm hub adaptors here>
http://www2.towerhobbies.com/cgi-bin...&I=LXJGR3&P=ML
Now if your after some serious offset and care more about performance and weight than anything you need to check these out>
Most offset you can buy> http://www2.towerhobbies.com/cgi-bin...?&I=LXJGS1&P=7
Great racing tire and really light weight to>
http://www2.towerhobbies.com/cgi-bin...&I=LXFNF9&P=ML
For more info on all this stuff go to > www.pro-lineracing.com Have fun!
RE: savage tires
Without going to 40 series RPM make a range of stablemaxx rims that widen stance by approx an inch overall.
http://www2.towerhobbies.com/cgi-bin...xx&FVPROFIL=++
The dyeable ones are the cheapest.
