rim and tire?
Old 12-17-2005, 11:23 AM
wave waker
Default rim and tire?
anybody put bigger tire n rim?..i'm using 2.2 tire and the outside diameter is roughly 4" and a hex, i want to get a bigger tire just to have higher ground clearance that will not need lots of modifications,,any recommendation?thanks
Old 12-17-2005, 08:36 PM
_iceman_
Default RE: rim and tire?
[link=http://www2.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=2.2+tire&FVPROFIL=++ &search=Go]browse thought here[/link] to find the tires you want. you will need to change your gearing if you change the size of tires
Old 12-17-2005, 11:32 PM
jakjr
My Feedback: (18)
jakjr's Avatar
Well you could try some Mashers, Moab's, or M2k's, they are all pretty big (around 5"s) and fit on regular 2.2 ST rims so no mods will be needed.
Personally, I like the looks of the Moabs - http://www2.towerhobbies.com/cgi-bin...?&I=LXLDK4&P=7 (Those say for the Jato, but if you read the description it says they fit any 2.2 ST wheels.)
Their's also the Imex All-T's, which are 5.5"s tall [X(] - http://www.imexrc.com/2.2TIRES_NEW.htm
Just keep in mind that you will probably need to drop a tooth on the CB to make up for the aditional torque needed to turn those big things.
IMHO, lower the body some, get some less flashy rims and paint/die them black, and put the All-T's on it. Would look good like that.
Old 12-18-2005, 10:14 AM
wave waker
thanks guys for the infos.,,,yeah, my tires don't look good and don't perform well, i'm getting one...
i took the body from my nikko rc and put it in the nitro kyosho 4wd, it's fun though, only that it's top heavy and too much body roll during hi speed turns,,still building it.
btw, what particular gear i need to change to maintain the torque or even increase?..i'm using .12 o.s. max cv....
Old 12-18-2005, 12:16 PM
jakjr
My Feedback: (18)
jakjr's Avatar
I would change the clutch bell, but you could change the spur gear if you want, only problem with that is you would need to go to a larger spur gear and a larger one may not be able to fit properly.
Basically either a one tooth smaller clutch bell, or a 4-6 tooth larger spur gear should do it.
