Draganflyer Objective Video
Day & Night Flight Video
This is some footage of my Ti Pro in day and night flights. The dayflight was with a slight headwind so I just dipped the nose into it and let it surf that wave, kind of like a thermal! I just pitched a little forward and it basically maintained its own altitude with only slight adjustments. The night flights are showing the use of the nav lights for orientation. The night flight at the stadium best demonstrates what bright LEDs can do when pointed straight ahead without any obstruction from the frame or motors. Since the night flight lights video I have added the red and green and will be adding four more landing lights.
Ti Pro Flight Video Demos
[link=http://www.jefcommunications.com/asx/helo/rcu/DFI/dayflights/DAYFLIGHT1.asx]Day Flight 1[/link]
[link=http://www.jefcommunications.com/asx/helo/rcu/DFI/dayflights/DAYFLIGHT2.asx]Day Flight 2[/link]
[link=http://www.jefcommunications.com/asx/helo/rcu/DFI/nightflights/NIGHTFLIGHT-LIGHTS.asx]Night Flight Lights![/link]
UT
RE: Draganflyer Objective Video
While the weather keeps me from flying, I've been trying to refine my video processing techniques. Here's the latest, my flash viewer. http://www.slcity.com/df
Here's to waiting for the snow to clear...
Scott
Scott
Scott:
Your camera work is very nice! Are you using the standard Eyecam Extreme Rig from rctoys.com in your videos and using a video editor stabilizer?
UT
Im also using a prototype for the new df eyecam. I also use 2d3 as my stabilization software. I have adobe prem pro and it comes with the 2d3 plug in.
Scott
Scott
I suppose even with the new camera rig there is no avoiding washing the video with a software based image stabilizer? No big deal I guess..........Thanks for the info!
ORIGINAL: Phodel
www.rcuniverse.com/forum/fb.asp?m=3922196
Here is another video that shows the DF in flight. He made his own custom camera mount.
www.imageevent.com/gdivideo/helicam
This is some recent aerial footage of the new SAVS in flight!
[link=http://www.jefcommunications.com/asx/helo/rcu/DFI/montage/MONTAGE1.asx]SAVS Aerial Long Shots[/link]
ORIGINAL: TheHindmost
Nice video and nice flying!!
(How 'bout some aerial shots from the SAVS itself?)
Will
Will
www.rcuniverse.com/forum/fb.asp?m=3811997
This is some close up aerial footage of the new SAVS in flight!
[link=http://www.jefcommunications.com/asx/helo/rcu/DFI/montage/MONTAGE2.asx]SAVS Aerial Close Ups[/link]
This is some recent aerial footage of the new SAVS in flight at night with nav lights!
[link=http://www.jefcommunications.com/asx/helo/rcu/DFI/montage/MONTAGE3.asx]SAVS Night Flight Lights[/link]
SKY HIGH
you placed a movie here I think it was the savs close up (ran for approx 6 mins around built up area)
I was amazed how steady the df was in flight, but what was suprising was the way the savs camera mount (golf ball bit??) was continualy moving back and forth and up and down, I can see that it is meant to with in the ring on the frame bracing, but it semmed that the shots would have been better on a fixed frame???
I dont mean to say you are wrong, for i have no idea, as my df is still in transit, but as a thought could low density foam be placed in that ring on the frame to stop some of the unnecesary bounce?
Just a thought, what do you rekon
Marty
Marty
cre8web, check out [link=http://www.rcuniverse.com/forum/fb.asp?m=4140876]this video[/link]. It has a split screen demo of a clean and processed shot and then [link=http://www.rcuniverse.com/forum/fb.asp?m=4141123]this video[/link] shows a totally clean version so you can see how that bouncing translates to the video. While shooting the objective video that you are talking about, I was flying for the ground camera and not for AP, so I wasn't as careful about hovering and make smooth transitions from each location. No matter how careful you are though, the camera mount will move. It's not as bad as it looks as you will see in those links.
Hi Sky High
Thanks for the reply, I am amazed at the way the editing removes that bounce, so i guess there is the answer, its prob way easier to remove that "ball shake" than interference and vibration, i am guessing.
I'm sure it said somewhere, but what software was that done with?
Marty
Marty
