Made the switch
My Feedback: (44)
Made the switch
Yeah, they have a little spring action built into them. Just make sure when you tighten the four metric screws that the turbine body is locked in securely. Some mounts were a bit over sized. The ears can be bent with pliers to form a flat 180 degrees to the mounting surface. Good luck you 'll love your JetCat!!!!
Made the switch
Thanks, Ehab.
I thought I might have done something wrong.
It seems really tight, so I don't think there'll be any problem.
Johnny
Johnny
