Yellowaircraft nose retract pin
Old 12-22-2005, 12:18 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Default Yellowaircraft nose retract pin
Well I guess I got one of the overly hard pins in mine, it broke off clean (looks like a broken drill). I took the gear apart trying to change this pin, and it seems to be pressed into this bushing.
Anybody got any idea how to get this out? Like most modelers I do not have a press at home.
Thanks in advance,
ID:	374207   Click image for larger version
Old 12-22-2005, 12:32 PM
seanreit
My Feedback: (60)
seanreit's Avatar
Default RE: Yellowaircraft nose retract pin
drill a hole the size of the pin in the wood in teh background of your picture.
Hold it against that hole, then use a scratch awl and beat it into submission till it comes through into the hole you drilled in the wood?
Just an idea
Old 12-22-2005, 12:33 PM
Gordon Mc
When you say you don't have a press - does that include a regular drill press ? Those can sometimes be used in place of a full press.
Any idea what the two different metals are ? Given the different thermal propreties of various metals, sometimes heating or freezing the part can help you remove a stuck part.
Old 12-22-2005, 12:34 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Good tip I tried that, with a torch on it to boot.
I can't believe it is on there this tight.
Old 12-22-2005, 12:35 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Good tip Gordon, I will go try the drill press
I am with you I do not know if the heating is helping or not
Old 12-22-2005, 12:42 PM
Gordon Mc
ORIGINAL: mr_matt
yup - that's why you may also want to try freezing it ... if the inner part is more temperature sensitive than the outer, then heating the assembly would make the fit even tighter, whereas popping it in the freezer for a wile would make it looser.
Old 12-22-2005, 01:00 PM
Kelly W
Matt,
I heated mine and it broke free pretty easily. Find some red (permanent strength) loctite for when you press the new pin in, in case the hole enlarges a bit from after removing the old pin or the new wire is slightly undersized.
how are the retract frames holding up?
Kelly
Nighthawk117
My Feedback: (41)
If you know anyone at a machine shop,they can drill it out with carbide or it can be EDM'ed out.
Old 12-22-2005, 01:04 PM
Gordon Mc
BTW, if this thing is just a press fit, then the hole may be tapered - in which case I kinda hesitate to state the obvious, but it can then only be pressed out in one direction.
Old 12-22-2005, 01:26 PM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Matt,
If it is Inconel or steel, propane torch and should slide out. If it is Aluminum, try a heat gun. I've hd problems like that before nd heat always seemd to be the answer.
If the metal gets red hot, slow quench it in oil, otherwise the sample may loose it's stiffness properties.
David
Old 12-22-2005, 02:06 PM
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Matt, do you have a big bench vise? If you do you can rig some spacers from some washers and put a pin into a piece of metal to hold it straight. A socket may hold the part securely while providing relief for the pin to be pressed out.
Old 12-22-2005, 02:12 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Thanks guys,
I am going to try the arbor press over at JetCat
Regards,
Old 12-22-2005, 06:51 PM
Kelly W
Matt,
I really don't think you'll need to get it hot enough to worry about ruining the metallurgical properties. The outside material is brass, inside is steel. Its likely put together with a small amount of heat and a high-strength retaining compound. If you heat it up on a household iron at full temp, that should be about right to soften up the compound. Just hold the iron upside down and leave the pin and retainer sitting on it for a few min... You might feel significant resistance at first, just to break it free, but one it moves it'll be smooth and easy on a press.
I think you'll make things worse if you throw a torch level heat into it, or think about machining the pin out. Having done this same swap on my Stingray, just stick to moderate heat and a press.
Later'
Kelly
PS: Nice paint job, how's your Stingray fly? I think I've got my elevon servo issues sorted out on mine, ready to test it out on ~7kg of thrust next season!
Old 12-25-2005, 01:18 PM
Shaun Evans
Shaun Evans's Avatar
Matt,
Put it in your oven at 350 for about 30 minutes. It'll fall out if you tap it with something at that point. Put your new one in while it's still hot and let it cool. Done it many times and it works.
Old 12-31-2005, 11:55 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Hi Shaun,
THanks for the tip. Sounds pretty tough to do at a jet rally. Can I get spare parts for these gear (side frames and the little brass busing, stuff like that?)
Hi Kelly,
It flies fine, the gear were bent on the first flight when I came up short. Second flight went fine. It needed less elevator expo, as the wings get heavy on elevator in the corners. I do not have a lot of experience with flying wings in any case.
Plane feels to me like a small scale plane, not only hot but heavy, fast approach, high sink.
Old 12-31-2005, 01:36 PM
Shaun Evans
Hi,
Matt, you won't have to do that at a jet rally. If you replace the pin, you'll be replacing it with music wire, right? It won't be a purpose-designed shear-pin like what was in there. I used 3/16th music wire after mine sheared off (ran it up onto a curb taxi-testing in the cul-de-sac). All the gear parts are available.
