Go Back  RCU Forums > RC Airplanes > Seaplanes
Sikorsky S-39 Build
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Sikorsky S-39 Build
Old 12-25-2005, 05:57 PM
Larry D.
Default Sikorsky S-39 Build
Has anyone had any experance with the Sikorsky S-39. The plans came from RCM plan service. The artical was in the 8/91 issue and was designed by Bob Rich. Any info would be helpful being all that came with the plans where several type written pages of instructions and not a copy of the orignal articale.
LarryD
Old 12-26-2005, 03:39 PM
Wayne22
Wayne22's Avatar
Default RE: Sikorsky S-39 Build
I have one that I am doing some repairs on, but did not build....
Old 12-26-2005, 05:00 PM
cyclops2
cyclops2's Avatar
I built a Martin China Clipper out of blue foam and the only thing I did was to Zerox several frame ststions along the hull to get the foam shape right.
It flies perfect on 4--400's.
ALL high wing planes are easy to CG and fly.
Make sure the first or only step is behind the CG and make sure the step edges are SHARP.
You want it to cause turbulance as the speed builds up.
Old 12-26-2005, 06:00 PM
Wayne22
Wayne22's Avatar
The S-39 is a pod fuselage flying boat suspended below a wing and twin booms with 29 struts.....
Old 12-27-2005, 11:58 AM
Larry D.
Great photo
Old 12-27-2005, 01:44 PM
Wayne22
Wayne22's Avatar
That's a drawing for someone's flight sim. There are a few pictures on the web - mostly of the giraffe colored one that was at Oshkosh.
With that cub wing, it flies great, but it is not too fond of choppy water. When yoiu get to that part, I'd recommend putting the aileron servo hatches on the TOP of the wing to keep them dry......
Old 04-28-2006, 09:56 AM
Larry D.
Finished and flown my 29. It wants to climb a lot. I built it right off the plans. have you had the same problem? Going to give the engine some down thrust and add a littlelead to the front. It would be a major project to take it apart to adjust the incidence, Have any ideas?
Old 04-29-2006, 10:32 AM
Wayne22
Wayne22's Avatar
hmmm.. I never encountered any problems like that..some down thrust seems like the simplest thing to try....
Old 04-29-2006, 06:39 PM
ronrange
My Feedback: (20)
I have a "sem,i-scale" S39 kit if anyone has interest. The kit is for an 09 engine and was made by Vintage Aircraft.
Old 05-01-2006, 08:35 PM
dicknadine
whats the wing span and recomended motor? also your sking$$ ? dick stamm
Old 05-02-2006, 08:27 PM
tail-rotor
follow this link to a video and some pics of the real thing. http://ossipeeaviation.com/antique.html
Old 06-04-2013, 11:44 AM
rcpropnut
My Feedback: (30)
Did you ever complete the Sikorsky S-39? I do have the origAug 1991 that has some building tips.
Old 06-08-2013, 01:32 PM
Avaiojet
I built one back in 91 and still have it. I striped it done for a redo. One day I'll get around to it.
Charles
Old 07-21-2013, 08:04 AM
edp
edp's Avatar
Here is a friend's of mine last month.
ID:	1902639   Click image for larger version
ID:	1902640   Click image for larger version
Old 11-25-2022, 10:42 AM
120boy
Default Sikorsky S39 from Uncle Willies Plans
[QUOTE=Avaiojet;11537448]I built one back in 91 and still have it. I striped it done for a redo. One day I'll get around to it.
Charles
Hello Charles,
I came across plans from Uncle Willies for a 76” WS model that I would like to build. It sounds like you have some experience building one of these / any tips or photos you could share?
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
