2 quick ones
2 quick ones
the savege atv(pictured) is the shocks ok? they are stock but is seems low??
also i wraped my 4.6 for breaking in in freezing conditions? will it work?
RE: 2 quick ones
because the stock oil is naff in thr RTR, would help a little if u changed to 30 - 35w also the black springs make it ride higher, as the green are softer
RE: 2 quick ones
try adding more spacers to the top of the shocks that will also help to increase ride height, keepin the truck lower also has advantages tho, ie turnin better
RE: 2 quick ones
cool thanks.
heat cycle here i come.
i will tune my atv today i heat cycle it at the weekend (hope i did it right first time) fingers crossed
VA
RE: 2 quick ones
You might see if the shocks need a little more oil. If they're not full, they'll sag like that. However you don't want them so full that the shock can't compress. Fill them to the point that the oil makes about a .5mm to 1mm bump, then cap em off. If it is sagging cause of low oil, cramming spacers in there will keep the shock from acting like a shock and the ride will be very bouncy.
RE: 2 quick ones
Oil wont effect ride height. Oil provides damping for the shock only. your truck should "sag" a bit from the weight of the truck for maximum efficiency.
Colindecon, when you lift the truck up how much do the wheels drop?
VA
RE: 2 quick ones
It shouldn't sag as much as his pics show. If there is any air in the shock the truck will sag. Making sure the shocks are full of oil will prevent it from sitting so low.
RE: 2 quick ones
ORIGINAL: podge_87
My Bad, Sorry
ORIGINAL: azzman
i topped up the shock oil now it looks better
