Revo with TM323 Gearing
Old 01-15-2006, 11:13 AM
richpadg
Default Revo with TM323 Gearing
I am running the TM323 (awesome) in the Revo and I race on a fairly small track. I need to know what the optimum gearing would be in this situation. Right now I am at stock settings. Any help would be awesome.
Thanks in advance.
Old 01-15-2006, 11:39 AM
awdspider
Default RE: Revo with TM323 Gearing
in my opinion you wouldnt want to lower the gear ratio at all. that motor has a lot of torque and it would probably be a hand on a small track........if its not already.
i would leave it the way it is now.
laters,
shaun h
Old 01-15-2006, 02:58 PM
itspuddingtime00
itspuddingtime00's Avatar
You might even want to consider a higher gearing to help control things a bit, like 15/36. Otherwise I'd keep it the same.
Old 01-15-2006, 09:04 PM
richpadg
Well, I stripped a few gears tonight at the races, so now I am running a 15/40 and standard ratio in the tranny. Pretty much was tearing the track up until a tie rod snapped on me. I will definitely have to gear down some. Thanks for the help.
Old 01-16-2006, 02:17 AM
RenegadeRevo
RenegadeRevo's Avatar
Personally, on a tight track... with a TM323.. I'd run a 16/36... w/ close ratio gearing... with the 16/36... you'll still need some throttle control... but not NEAR as much.
Old 01-16-2006, 05:41 AM
RBd Revo
Totally agree with RevoFamily.. I run 16/36 - close ratio, on a fairly technical track and find it has enough low end as well as top. Gearing down any just means I'm losing traction from wheel lift.
