Help.. Servo Buzzing noise.
I just installed an Airtronics 94358Z ERG-VR Servo for my steering on my RC Monster Truck and before I installed it I tested it and , there was no noise at neutral nor when it was turned left and right at its end points but now that I have it installed it in my Jugg 2, it tends to make a buzzing noise when it is at its end points left and right but fine in neutral. Is there a problem? What do I need to do to remedy it? Is it normal? Is there too much load at the endpoints or something?
Please let me know.
Please let me know.
Re: Help.. Servo Buzzing noise.
Please let me know.
Please let me know.
Try and re-set it to neutral. Make sure you have the radio and reciever switch turned on so the servos are in the neutral position. Then make whatever adjustments are necessary to stop the binding / noise. Test it again to see if that fixed it. If you are using old servos then it's possible that you'll need to restore / rebuild them or buy new ones.
Good Luck!
My Feedback: (158)
If you have a computer radio, just dial out your ATV or your dual rates until the buzzing stops
If you have a regular porprtional radio with out dual rates, you'll have to move the linkage in on the servo horn to reduce the throw, that way it wont bind when you reach full travel
Good luck
Good luck
