mini stick
mini stick
i took the axlesfrom the mini nylint crawler and took a wooden dowel and joined the axles were the original axles mounted to the suspension.it works great and eventually i will put aluminum insted of woodand make it look good.. and i will gets pics of it after school.
RE: mini stick
i still have stock tires and i will put bigger one on it wen i get a chance. andi left out i put a jr survo mounted with erector set peices.
RE: mini stick
oh come on, that has nothing to do with it:P we're still anxious to see the only ghetto-engineered crawler
OH
RE: mini stick
D-crum, you use what you have. that's the basic rule of building anytihng on a budget. I think it's ingenuitive. Ghetto as hell, but ingenuitive, and shows motivation to get what you want.
C-crum, I dig it. now get us some action shots
RE: mini stick
lol i did not use a freakin pencil D-crum and thanks thunderberdjunky i will try to fix it again and and i will see if my brother will let me use hes video camra
RE: mini stick
I love it. That is like 20 minutes of destruction and reconstruction plus 2 dollars worth od materials, and I bet it's capable. Very nice, my 13 year old brother doesnt even know what ESC stands for, let alone biuld anything.
RE: mini stick
thanks i have been helping my dad work on his car and fixing lawn mowers and weed eaters since i was like 6 or 7 so i didnt just happen over night lol thanks for your complement and yes it works great but i keep breaking the wooden shaft that holds the tohalfs together so im probly going touse aluminum or like carbon fiber.
My Feedback: (20)
PA
RE: mini stick
towerhobbies carries loads of material, I think CF would work awesome probablly,its really hard to snap, just make sure it doesnt crack at one of the ends, cuz the crck will turn into a full length split, also is CF has force applied it will bend slightly(alsot less than the wood) and snap right back to its original form, whereas aluminum just bends, and its so light...Id try CF first, if you have something into the end of the CF tube try tightly wrapping thread(preferably kevlar thread, which tower probablly has) then while its still tight coat it with CA glue, that will prevent the cracking at the ends...
