engine priming
engine priming
i can't figure it out. i have a t maxx and i can't get the fuel to reach the engine. i have tried putting my finger over the exhust and nothing. is my piston and sleeve shot? someone please help. btw it has a trx 2.5
RE: engine priming
the gasket from the header toi the motor is just a little orange O ring right? if there is something else it isn't there. oher then that everythng is ok.
RE: engine priming
no thats all you get a little orange rubber seal,how much fuel have you used with the engine ?also take your pipe off and blow through it as it might be blocked pressure nipple(cover the stinger and blow though the outher end and the air will come out the the nipple)
RE: engine priming
i just replaced the piston and sleeve. shortly after break in i had a run away. the truck ran full throttle for a pretty long time until it got wedged under a fence. that is why i thought i may have to replace it again.
RE: engine priming
what other options are you talking about? after the fence, i broke A LOT of peices and just finished putting it back together. everything is good to go all the wat down to the diffs.
RE: engine priming
i figured it out, i had the one-way in backwards. the engine was blowing air instead of sucking air. What a stupid mistake. thanks for your help. Brian
