ZDZ Thottle hook-Up
Old 11-28-2002, 05:23 AM
mlj3
My Feedback: (95)
Default ZDZ Thottle hook-Up
Could anyone with this engine tell me the best way that they used to hook-up to the thottle arm that is on the Bing#48 carb.On mine the stop screw is in the way on one side and the adjustment screws are in the the way on the other side.It will not let me get a straight shot to the hole that is in the thottle arm. Thanks in advance MJ
Old 11-28-2002, 11:38 AM
Bob Pastorello
My Feedback: (198)
Bob Pastorello's Avatar
Many owners of the ZDZ just use a cut off wheel to remove the throttle stop screw/mounting bracket. That gives you a straight shot, and you don't use the stop screw in airplane applications anyway.
Old 12-02-2002, 01:09 PM
Mr T.
You don't even have to grind the bracket off. For me it was enough to just remove the stop screw. I enlarged existing hole (for 3mm screw) in the throttle arm and used a ball link and sullivan goldn rod to connect it to the servo.
