Onboard Voltage monitor display???
My Feedback: (19)
NC
I have seen a few planes with a small digital display onboard displaying voltage. Where do you pick one of these up at and how much do they usually run?
My Feedback: (40)
IN
RE: Onboard Voltage monitor display???
Use this link..... Rod carries th best stuff on the market. I use his stuff in my planes all the time.... FLAWLESS
[link=http://www.i4cproducts.com/c-volt.htm]I 4 C Products[/link]
i have fromeco 7.4 v 5200mah lithium ion batteries
will the Duralite - onboard digital Voltage Display Meter work with it
it says "Real Time digital reading of pack voltage. To be mounted on the airplane. Voltmeter for NiCd, NiMH or LiPoly Batteries. 1.375" x 0.875" x 0.5"
BC, CANADA
Emcotec offers a complete battery monitoring system for single or dual battery setups. Displays several things, voltage, amperage, etc etc. Desert Aircraft is the US distributor for the product, but you can view the products here. It is called a DPSI BMS...
[link=http://www.rc-electronic.com/html/englisch/englisch.html]Emcotec[/link]
do you mean this
"The DPSI BMS is the first monitoring and displaying system for batteries used in dual power supplies in large scale models. For operation, the DPSI BMS is simply put in between current source (e.g. batteries) and consumer (e.g. battery switch). Turn-on and turn-off works fully automatically, as soon as current flows (equipment turned on) or no current flowa (equipment is turned off). The DPSI BMS displays all important measuring values in plain text. Besides battery voltages and current flows of the connected cosumers (minimum / average / actual / maximum values), withdrawn capacity as well as operating times are displayed."
will it read fromeco 7.4 v 5200mah lithium ion batteries ?
