YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 63 fuel problem
Old 02-20-2006, 06:45 PM
Bas_mvsb
Default YS 63 fuel problem
Recently I bought a half finished seduction freestyle with a ys 63fz. When I bought it the engine was running great (I've runned it with wildcat 30%) but 4 weeks later I wanted to make my maiden flight with the freestyle. Unfortunately without success. The engine didn't run because it didn't get any fuel from the regulator. At home I carefully disassembled the regulator and cleaned it but without any success.
Does anyone knows what could be wrong? I live in the Netherlands and a YS engine is pretty unique here so there aren't much people here who have the knowledge to repair a YS. So i hope maybe someone here at this forum could help me.
Bas van Lieshout
Old 02-20-2006, 08:34 PM
Dave Shadel
Default RE: YS 63 fuel problem
Is the fuel tank building pressure? Make sure the check valve is working correctly.
Old 02-21-2006, 02:34 AM
Bas_mvsb
The check valve works correctly and the tank is holding it's pressure when you blow air into it. But the regulator doesn't pump air into the tank. Everything is plumbed as on www.yspeformance.com.
So I think somethings wrong with my regulator.
Old 02-21-2006, 06:28 AM
hummingbird111
hummingbird111's Avatar
i think you are suppose to run the motor with YS-Saito 20/20,,, that's what i run mine with ,,check your glow plug,, if thats not it then check & make sure the regulator screw is flush with the caseing it screws into,,,
Old 02-21-2006, 11:47 AM
Dave Shadel
Difficult to tell without seeing the engine, sorry
Old 02-23-2006, 11:18 AM
Bas_mvsb
I found the problem. When I took the regulator of to clean it I probably turned it around 180 degrees when I mounted the regulator back . So when I disassembled the regulator again I saw there was a back and a front and when flipped it again the YS runned great.
Thanks for your help anyway dave.
Old 02-27-2006, 11:53 AM
Dave Shadel
They work so much better when put together correctly.
Glad you found the problem.
Old 04-23-2006, 04:01 PM
kaseyk1
Dave,
Hate to sound stupid but how can I tell which way the regulator housing goes back on?
Terry
