RCUniverse.com/GP Flatout Bipe for G3
RE: RCUniverse.com/GP Flatout Bipe for G3
ORIGINAL: DesertRC
Zelatio-
Thanks..Brain fart!!!![sm=spinnyeyes.gif]
Zelatio-
MA
I'm having trouble getting this to work in G3 version .430 I get errors about missing components when it loads. Anyone else having problems or just me?
Carl
Carl
PA
make sure you save the G3X file on the desktop as the G3X, not a zip, then import. I had the same problem, and the ailerons wouldn't move.
After you download the g3x file, start up g3. Then click on simulation in the top right corner, then click on import than g3x. Next find the g3x file on your computer and click ok. If every thing worked right the plane will be under custom aircraft in the select aircraft option. It may take a little wile to load the first time but after that it will load a lot faster. Hope this helped
Ps. I seen some post to make the prop pitch on the throttle stick so that when you go all down it will fly back-wards. I just modded and upped it to the same thread where you get the original from on KE. >>> http://www.knifeedge.com/forums/show...7396#post47396 Post number 29
Gizmo
Gizmo
VA
My problem was that I didnt install the update since I got G3. I have done that and wow this is a stable plane! Seriously is it like that for real?!
The version that flys pretty darn close to my real RCU Bipe is now up. Post 38.
http://www.knifeedge.com/forums/show...t=12013&page=3
50%
50%
WOW folks! This has got to be the most popular model that Rick has made!
1516 downloads from www.rfmodels.com
614 downloads from www.knifeedge.com
2130 downloads total!
