Shock absorbing Landing gear
Old 12-06-2002, 11:54 PM
Jim Finn
Jim Finn's Avatar
Default Shock absorbing Landing gear
I have built and used a shock absorbing landing gear system that I have used successfully on three tricycle geared airplanes. "Astro Hog, Tigerkitten and Super Kaos" Weighing from 4 to 9.5 pounds. it weighs about the same as wire gear. I use R/C car shocks which cost about $15 a set of two shocks. Install them just like the swing arm is on a motorcycle. Landings are bounce free on the grass field I fly from.
Old 12-07-2002, 12:22 AM
tonyc
tonyc's Avatar
Sounds like it should work. Can you post a picture?
tony
Old 12-07-2002, 09:38 AM
jetflyer
jetflyer's Avatar
Can you email me a picture of your shock mounted landing gear?
[email protected]
thanks,
JR
Old 12-07-2002, 01:00 PM
Flying Hog
Flying Hog's Avatar
I'd Like some pictures also.... Thanks!
[email protected]
Old 12-07-2002, 02:19 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Shock absorber mounts ? Gotta have a pic of this ! Jim, please email me too and thanks...............
Old 12-07-2002, 02:29 PM
ricdel
My Feedback: (9)
Hello all!
If one of you other guys get a picture maybe you can post it here for all of us other ones that would love to see this neet idea.
Old 12-07-2002, 02:56 PM
Jim Finn
Jim Finn's Avatar
Photo : The arm on the left pivots at the acft. mount the other is rigid
Old 12-09-2002, 01:47 AM
GALENM
Where did you get this.
Supplier
Manufacturer
Part number
Looks slick
Galen
Old 12-09-2002, 01:55 AM
Jim Finn
Jim Finn's Avatar
Galen................Read the first post on this thread. It explains that I made it myself with piano wire and R/C car shocks.
Old 12-09-2002, 04:57 PM
knpjdad
knpjdad's Avatar
Cool!! Wonder what shocks I would need for a 18lb plane?
Old 12-09-2002, 05:29 PM
GALENM
Please help this newby.
Is the front strut the like the original LG strut which is normally mounted 90o on the wing. Is this canted back to act as a spring.
Or is this front strut hinged at the front with no spring action relying on the rear to take most of the down thrust. In that case where is the spring action?.
I presume you made modifications to the wing to take the forces applied to the wing.
Galen
Old 12-09-2002, 11:11 PM
Jim Finn
Jim Finn's Avatar
THe front arm pivots in the Landing gear block, which is a grooved block of hardwood ,5 inches long, inside the wing. The rear one is fixed in anothor landing gear block inside the wing. The spring action is all inside the shock absorber. When I land with this system it does not bounce at all and it taxies and takes off just fine.
Old 12-11-2002, 04:58 PM
MinnFlyer
MinnFlyer's Avatar
Interesting setup!
Old 12-12-2002, 05:17 AM
h8w8n
Default shock mount.
Jim, how does the top of the shock obsorber attach to the bottom of the right hand strut? It has to be ridged, right?
thanx.
Old 12-13-2002, 07:03 PM
Jim Finn
Jim Finn's Avatar
Both ends of the shock attach the same way. The wire strut runs through the end "I bolt" and is held there with two wheel collars. This allows it to pivot a little. The two "I bolt" ends of the shock are a bit large so I shimmed the wire with fuel line hose. This setup allows the wheel to swing aft and up on landing about 3/4 inch. Doesn't seem like much but seems to be adequate. Need to check for prop clearance with shock compressed when deciding how tall to make the L.G. Sent you a private message with more info.
Old 12-13-2002, 08:14 PM
GALENM
I take it the front mount is the original position of the LG and this causes the LG to be back of it's original position. Any problams with balance?
do I read it right that the rear strut is anchored to the wing and then terminates with an L Bend which goes through the "eye bolt" end of the shock.
similarly the front strut is hinged at the wing and ends with an L Bend. Does the lower end of the shock and the wheel slip over this L bend possibly held in place with collars?
I presume that the rear strut has to take the bulk of the downward force.
Would it work to place the rear strut into the original LG mounting block and create the new anchor for the front strut ahead or the original LG block. I presume that this block would only take the force of the foreward motion.
Thanks for the help
Old 12-14-2002, 12:42 AM
Jim Finn
Jim Finn's Avatar
Yes you understand it perfectly! In order to decide where to put the L.G. blocks I made a full scale sketch and positioned the blocks to put the wheel at the same location shown on the print that came with the airplane kit.
Old 12-24-2002, 05:24 PM
scalebldr
My Feedback: (7)
Default rcm c-45 plan
hello,
thanks for this idea,this will work great to solve the problem of the landing gear using g-pad in the rcm plan of the beech c-45.i will use the shock absorber instead of the g-pad.plane should weigh about 4-5 pounds,what type shock absorbers would you recommend.thanks.john
Old 12-24-2002, 10:15 PM
Jim Finn
Jim Finn's Avatar
Default LG
I suggest you get the smallest lightest ones you can find. That is what I did. I have used the plastic ones and the aluminium ones and they both work fine but the plastic ones are lighter and cheaper. The one in the photo is aluminum. Good luck..Jim
