9zwcII and us 40 programing help??
I have a new us40 that I am trying to figure out how to program my radio to do the crow. I thought I saw a thread on here about it, but darn if I can find it on here. Is there anyone out there that can help me do this in great detail? Please help...
Can the US 40 do the crow?
The US 60 is set up to do the Crow by using separate servo's for each aileron and flap surface. Each servo is put into a separate channel.
So you have 2 flap and 2 Aileron servos. If you go to the futaba site, and look for the following:
Futaba-rc.com/faq/faq-9c-q515.html
it will tell you how to set up for the Futaba 9c.
There should be a direct carryover to 9Z.
In additon, if the US 40 can do the crow, the programming instructions should be in the manual, if you have added your own flap, then I would look for the pdf for the manual for the US 60, that will give you programming for the Crow function.
Hope this helps solve your problem
Steve
Steve
