tuneing carb on savage 25
RE: tuneing carb on savage 25
The top of the adjusting screws you turn should be flush with the top of piece they go in. That should be close to stock settings .
NY
i'm pretty sure the hsn is 4 turns from closed so close the neddle all the way not tight then open it 4 turns counter clockwise the lsn i think is 3 turns from closed but check the manual
