new motor but no go
MN
new motor but no go
hey i just dropped my picco 27 in new clutch bell new alum clutch shoes new spur and i was breaking it in and all of the sudden it wasnt moving .... so i figured spur gear checked it out spur is fine ... then i checked the clutch shoes to make sure they were installed right and yup yup same as the manual says i even put my old ones on thinking that maybe the alum shoes were no good ... clutch bell and the spur still spins ... any ideas????? i want to finsh breaking this bad boy in i got it up to about 220 degrees gave it almost full throttle and its way faster than the .25
QC, CANADA
RE: new motor but no go
Does your spur turn freely in both dir? Cuz if so you might have a busted tranny.
My friend had a similar problem last week, turned out that his spur was on to loose and the center melted away till there was no traction at all and he also had no damage on the teeth so check that out and if its all good then you might have to open up the tranny.
MN
well i've been fighting this thing for like 6 hours now last night putting in the engine and taking apart the old one and now with this crap im so pissed i just dont even want to work on it anymore .... i got about 1/4 tank thru and thats it .... the spur is tightened but does spin in both directions but i think it always has .... but when i spin the spur with my finger it used to turn the wheels but now it doesnt ....
MN
when i lift it in the air yes the dog bones turn and the wheels do too but when i put it on the ground no wheel action and i would guess the dog bones are not turning either ...
QC, CANADA
Ok, try turning one of the front wheels while blocking the other to see if its getting transfered to the rear (prop it up on something), turn it in both direction then repeat in the rear. If anything is wrong with either diffs or tranny you should be able to hear some grinding or something, if not then i say check the spur again to see if it melted in the center.
MN
ok i think i found out what it was i took a break went and took a nap woke up in a better mood ..... i checked the spur assembly and i used a smaller brass washer inside the spur gear on accident .. had 2 laying on the table and grabbed one of them opps wrong one well anyways im going to go out and try it right now ...
MN
k it works now too small of a washer .... dumby .... i still would like to get thru more than a tank without a prob .... glow plug went bad this time replaced it and started it and it died tried to restart and now the rotostart is slipping so i have to tear it apart again ...
QC, CANADA
ORIGINAL: trayman
MN
i dont know what the hell is going on with this .... but yes its slipping so maybe i flooded it when the glow plug went bad and that caused it
MN
yes the back plate for the s-25 but i picked up the ofna back plate but then i cant get the roto start will not fit in because of the shock tower ... i took the gear out of the ofna and swapped the gears and it worked well .... or so i thought . how did you do it ??
MN
well i thought this way would work but ill try putting a hex nut in there .... i have to tear it apart again anyways forgot to put the alum clutch shoes back in ... put the stock ones in to trouble shoot ... does yours do wheelies on pavement ??? i noticed that mine was about ready to but i didnt want to go full throttle yet ... have you raced anybody with it ?? i want to shut my buddy up with his revo
MN
thanks for your help to man ... really helped me out and kept me from punching holes in the wall today waiting for responces ...
QC, CANADA
Up untill recently i had no one to ride with but two of my buddy's couldnt resist and both got savages, one of them has a orion wasp .26 wich is basicly a picco .26 (exact same everything exept for cooling head) and i beat him no problem but i have a 3 speed and dirt bonz while he has a 2 speed and stock t-maxx tires so no contest there. I also have a used collari .30 i got off ebay this winter (only 3/4 gallon in it) i cant wait to try it out when it gets warmer. Im sure you wont have a hard time shutting up your buddy, just remember that it takes at least 10 tanks before you start to see some real power and about 1 gallon for max power.
EDIT: and yes i wheelie all the time, this engine is IMO the best for the savage because it doesnt have insane bottom end that makes uncontrollable, just enough to show off to the usual spectators or to launch off for a race AND it has a great top end for really good top speed. I have a ribbed pipe on it and i like it better than the dual chamber, but thats just me...
QC, CANADA
ORIGINAL: trayman
NY
well it looks like you got the answers you neede but dont let it stress you out too much, you will go through times when it seems like neverending PITA problems but when all is said and done and you spend the time to tune the carb it will pay back greatly (especially that engine). when these cars run the way they are supposed to they bring smiles to everyones faces. so always just hang in there and think about how awesome it will be when its done......just trying to help your morale a bit cuz i know how you feel (or felt)
