Revo noise while starting
PA
While starting my Revo with the ezstart there seems to be a ratting noise. Starts fine.
Is this coming from the ezstart or oneway bearing?
I plan on taking apart. What should I be looking for?
What prventive maintanence should I take in keeping the ezstart starter/one way bearing working good?
RE: Revo noise while starting
Could be the one way. Just open it up. Check everything make sure it looks ok.
Remove the one way. Clean it with Wd-40 real well. They dip it in motor oil then re assembly.
Your lucky if this is your first own way bearing maintenance. I have to clean mine every 1/2gallon - gallon of fuel.
I believe the clutchbell rattles a little at idle also. makes a ding-ding sound, barely noticable at idle. This is not a problem.
