Dreamworks Offically Moved...
Old 03-31-2006, 09:23 AM
lov2flyrc
My Feedback: (24)
lov2flyrc's Avatar
Default Dreamworks Offically Moved...
Dreamworks Model Products has completed the move to our new location. We are still without internet access until wednesday so order processing will still be a bit slower than usual but we are shipping.
Thank you for your patience and patronage!
Todd
Old 03-31-2006, 09:33 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Default RE: Dreamworks Offically Moved...
Todd, mounted the thrust vector and merlin last night and this morning. Servo Mounts are glued in and curing for the control of it. Dude, I love the design. Thanks a bunch!
Old 03-31-2006, 10:38 AM
ghost_rider
My Feedback: (20)
ghost_rider's Avatar
ORIGINAL: seanreit
How much did you pay for the t/v?. I had one from TAM (4-axis) but I like the way yours was made with full attachment to the turbine.
Regards
Ben
Old 03-31-2006, 11:00 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Ben, I think Todd posted in another thread that it's around 200 bucks
http://www.rcuniverse.com/forum/m_40...tm.htm#4027860
There it is.
Old 03-31-2006, 11:05 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Here it is installed. My only concern is the unit comes with stubs, and the only thing I could get to work was plastic fittings. I don't know about heat if it will mess them up. Anyone want to chime in?
ID:	436505   Click image for larger version
ID:	436506   Click image for larger version
ID:	436507   Click image for larger version
Old 03-31-2006, 11:12 AM
seanreit
My Feedback: (60)
seanreit's Avatar
The top one is on a "U" and I don't think heat will transfer there. But the side stub goes all the way through to the inside of the pipe. I'm pretty sure heat will transfer out on it. How much, I don't know.
What I was gonna do is just run the thing at idle for a few minutes and just see if they get soft. If so, I don't know what I'll go to. Any ideas would be appreciated.
Old 03-31-2006, 11:34 AM
Gordon Mc
My memory is kinda fading on this issue, but isn't / wasn't there an AMA reg that stated that such devices could only be used if they were manufacturer designed or approved ? Or was that only for thrust REVERSAL, not for vectoring ?
Good luck with the new premises Todd - glad to see that you're doing well enough in the business to need such expansion.
Gordon
Old 03-31-2006, 11:36 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Gordon, no thrust reverse is allowed. Vectored thrust is not addressed one way or the other.
Old 03-31-2006, 12:07 PM
seanreit
My Feedback: (60)
seanreit's Avatar
After some headscratching, I made up a small piece of flat aluminum stock, put a hole in it for the stub up, nuted it on, made a small hole for my metal control, plugged it together, works perfect!
Old 03-31-2006, 02:27 PM
DaveMatthews
DaveMatthews's Avatar
Todd,
Just sent you a PM on the 2 axis thrust tube.
Cheers,
Dave Matthews.
Old 03-31-2006, 02:56 PM
lov2flyrc
My Feedback: (24)
lov2flyrc's Avatar
Dave,
PM Replied too... Pricing is 185.00 + shipping for the D/A Vector nozzle. We currently have the Tamjet unit in stock, the unit Sean has above are due in second week of April...
Pre-orders being taken now....
Todd
Old 03-31-2006, 03:03 PM
seanreit
My Feedback: (60)
seanreit's Avatar
http://www.my87.com/video/100_0860.mov
Video
Old 03-31-2006, 03:06 PM
DaveMatthews
Thanks for that Todd,
p.m. sent right back to you.
Dave
Old 03-31-2006, 05:29 PM
Gazzer
Gazzer's Avatar
Todd,
might you have time for that beer in the next two weeks from Friday 7th?
What part of the beach is the best for us tourists to hit and what day is best?!!!!![8D]
Appreciate your busy so no worries, but if your in need of a slight break, PM me!!
Cheers,
Gazzer
Old 03-31-2006, 08:45 PM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Nice vid Sean! I would love to try this out! Could anyone describe how the merlin performs? Very interesting power and fuel usage. How does the throttle feel? Nice looking motor.
Congratulations on your new place Todd! I will put an order in soon.
Joe Kelley
Old 03-31-2006, 08:53 PM
seanreit
My Feedback: (60)
seanreit's Avatar
I own Two Merlins. There were some growing pains with a new engine, but all kinks have been worked out. The one on my kingcat is unbelievable performance. It's loud as can be, and gobs and gobs of blow.
I expect on this rookie which will be considerably lighter than my kingcat to have accelerated unlimited vertical on take off. That along with the thrust vectoring should be quite a show.
My biggest conern right now is over rotation on first flight
Gonna have to come off the ground gently!
Old 03-31-2006, 10:40 PM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Sean, how much fuel do you carry on board your king cat and how many minutes do you fly? What do you mean by growing pains? I thought this engine has been around a while? The TV2X should be really fun. I feel like my rookie could use it. THe pitch only is ok but needs something.
Joe
Old 03-31-2006, 11:28 PM
CARBUNCLE
what size merlin is that? a 160?
Old 04-01-2006, 12:27 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Merlin is more power than a P-160.
I carry the Kingcat tanks and the mueler smoke tank, I use the smoke tank as a center fuel tank. I fly 12 minutes with plenty of time to spare, even if I'm burning up the sky.
The rookie carries significanlty less fuel, but the flight routine will be much more intense.
Old 04-01-2006, 10:48 AM
CARBUNCLE
so it is classed as a 160?
Old 04-01-2006, 12:13 PM
seanreit
My Feedback: (60)
seanreit's Avatar
I don't know. I can tell you it's in the class as the Rhino, Pegasus HP etc.
Step up from 27 lb class.
Step below 42-45 lb class.
Last one I ran on the stand put out 36.25 lbs of blow
