HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
gas not going through fuel line.
Old 04-03-2006, 04:44 PM
mfishman
Default gas not going through fuel line.
hey guys,
my gas isnt going through my fuel line i tried putting on new fuel lines it still wont work. and yes i know how to prime it. thanks
Old 04-03-2006, 04:47 PM
fxrs
fxrs's Avatar
Default RE: gas not going through fuel line.
How are you priming it ?
Old 04-03-2006, 05:12 PM
mfishman
putting my finger on muffler and pressing the roto start
Old 04-03-2006, 05:15 PM
dnasty
make sure the glow plug is in tight enough. does the engine start? if not, remove the end of the fuel line that goes into the muffler and blow in it to force the fuel into the carb. infact, this is how i prime it every time i start it. good luck
D
Old 04-03-2006, 07:15 PM
SmoothInc
if your low speed needle is too far in it proly wont prime cuz that was my problem so you might want to try richening it up
Old 04-03-2006, 09:13 PM
fxrs
fxrs's Avatar
when was the last time this truck was run before this problem?
Did this truck set for awhile with fuel in tank?
Did you check the O ring on fuel tank lid for leaks?
Is the exhaust header gasket between the header and the engine
block ripped or missing? Need some clues to help you.
One easy one , are you sure the fuel tank lid is completely
closed?
Old 04-05-2006, 02:51 PM
mfishman
ok guys i tried to diagnose the problem and i found it. it wont go through the carb i tried taking out the needles fuel still doesnt flow thrugh. i know this because i took the line out from the car and blew through the other tube and it goes through but when i put it back on the car it doesnt go through
Old 04-10-2006, 08:37 AM
mfishman
help. pleaseee
Old 04-10-2006, 03:33 PM
DaveG55
DaveG55's Avatar
Well, if the blockage is in the carb, take the carb off, dissassemble it and clean it. I think you can get a rebuild kit so that you can put in fresh o-rings, etc.
Don't try to clean it on the engine, you don't want whatever is blocking it up to get into the engine.
Old 04-10-2006, 06:42 PM
itspuddingtime00
itspuddingtime00's Avatar
Take off the carb and disassemble everything, then flush out the fuel nipples and needles with fuel and put it all back together once it's totally clean from debris. Then I'd suggest getting a fuel filter so you don't get any dirt in your carb, and you don't risk ruining your engine.
Old 04-10-2006, 08:17 PM
basherJR
I do the same thing as dynasty
Old 04-10-2006, 08:22 PM
DaveG55
DaveG55's Avatar
ORIGINAL: monstertruck madness
Yeah, blow anything blocking the fuel on into the engine. That's a real good idea......NOT
Old 04-10-2006, 08:57 PM
benzzyo5
benzzyo5's Avatar
dave he said to take off the carb. remove from the engine so when he blows into it, it doesn't get into the engine.i don't know maybe i'm wrong[&o]
Old 04-10-2006, 09:33 PM
DaveG55
DaveG55's Avatar
Maybe I was a bit harsh. Sorry, just hate to see advice given that can harm someone else's stuff.
Dynasty said take the fuel line off the exhaust nipple and blow into it to force fuel into the carb. That's fine for priming (which is what dynasty was saying) but a poor way to clear a blocked carb.
itspuddingtime and I were the ones that suggested taking the carb off to clean it.
Old 04-12-2006, 10:18 AM
mfishman
ok so i take it off and clean it?
Old 04-12-2006, 10:47 AM
bhinton
check the o ring on the tank hold one finger on the fuel tubeand take theother tube and blow through it if it hold pressusre then you do not have a leak in the tank if not then check the o ring
Old 04-12-2006, 06:23 PM
DaveG55
DaveG55's Avatar
ORIGINAL: mfishman
If you've eliminated all the oyher posabilities like air leaks, etc. Then, yes, I would take the carb off, take it apart and clean it and put all new seals, o-rings on when it goes back togeather.
