HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
*****Dual Exhaust For Savage???!!!*****
Old 04-07-2006, 06:48 PM
gmaster1
Default *****Dual Exhaust For Savage???!!!*****
Does anybody know if you can use a roto start system with the Slimline Manufacturing dual rear exhaust? You can view the exhaust at www.towerhobbies.com
Please answer
Old 04-07-2006, 07:10 PM
dracy69
dracy69's Avatar
Default RE: *****Dual Exhaust For Savage???!!!*****
yes you can
Old 04-07-2006, 07:12 PM
gmaster1
have you ever used the exhaust before?
Old 04-07-2006, 07:14 PM
dracy69
dracy69's Avatar
nope but my friend has
Old 04-07-2006, 07:19 PM
icecreamslick
My Feedback: (9)
icecreamslick's Avatar
I just put one on my Savage LE. It came with the wrong screws (should have two 5mm hexes) and it does not work really well with the Rotostart, IMO. The mounting bracket partially blocks the space that the Rotostart shaft goes through and the pipe itself gets in the way, too. I had to take it off and do some bending to the bracket in order to make it work.
It is also difficult to prime the motor, since you have to put a finger over both stingers and run the Rotostart at the same time. It is especially hard for me because my glow plug igniter will not attach to the glow plug unless I'm holding it (broken) and I usually blip the throttle. I look like some sort of contortionist when I'm trying to get it started. []
One more thing....it may be just me, but the truck seems to have slightly less power with that pipe than it did with the original LE pipe.
Jason
Old 04-07-2006, 07:21 PM
dracy69
dracy69's Avatar
my friend jumped from the stock engine to a supercharged .26 so i dont know how the pipe did with power......he didnt really mind wedging the roto in there......
Old 04-07-2006, 07:22 PM
gmaster1
Do you have any piatures of your savage LE?
Old 04-07-2006, 07:24 PM
gmaster1
where did your friend get a supercharged .26 from?
Old 04-07-2006, 07:25 PM
dracy69
dracy69's Avatar
rb innovations makes the supercharger. dont get it
Old 04-07-2006, 07:29 PM
gmaster1
Does the supercharger shorten the lifespan of the engine or something?
Old 04-07-2006, 07:30 PM
icecreamslick
My Feedback: (9)
I just finished running the truck, so it is grimey. I took a few pictures, but my camera sucks, so I'm not sure what you will be able to see in these pictures:
ID:	440660   Click image for larger version
ID:	440661   Click image for larger version
ID:	440662   Click image for larger version
Old 04-07-2006, 07:33 PM
gmaster1
The pictures are not that bad. If you could maybe get a picture of the part of the engine where the roto start is that would be great.
Old 04-07-2006, 07:46 PM
icecreamslick
My Feedback: (9)
These pictures are worse because I cannot take close up shots with this camera. You probably cannot see it, but the second picture has the Rotostart shaft in place and it is touching the top of the bracket and the bottom of the pipe at the same time. The shaft of the Rotostart and the bracket rub enough that it is wearing the metal on both. []
This is my first attempt to use this pipe, so I will have to do some more bending before I try to start it again. So far, I'm not happy at all.
I've got to go and get my son out of the tub.....be back, later.
Jason
ID:	440671   Click image for larger version
ID:	440672   Click image for larger version
Old 04-07-2006, 07:56 PM
gmaster1
Thanks for trying to get some good pictures.
Old 04-07-2006, 07:58 PM
gmaster1
does anybody have a dual exhaust on a savage 25 rtr?
I appreciate your reply
Old 04-07-2006, 09:48 PM
trayman
that pipe is okay for road use on any kind of savage but if you do any bashing kiss that thing good bye ... i tried one the first day had a bad landing on the rear bumper and broke the pipe right in half
Old 04-08-2006, 06:08 AM
bibo
bibo's Avatar
Here's another one from TSAIS
http://www.tsais.com/products/exhaus...s/mt/c5H2.html
Old 04-08-2006, 12:19 PM
-SomeGuy-
-SomeGuy-'s Avatar
ORIGINAL: bibo
If i would get one i'd get this one.
Old 04-08-2006, 04:38 PM
Polar_Bus
ORIGINAL: gmaster1
Please answer
Dude, those "dual" exhaust systems are the BIGGEST ripoff gimmick, and a TOTAL waste of money! The kill top end power, and hinder rotostart operation. A nitro engine needs a tapered "divegerant cone" style exhaust to help scavenge the cylinder for top performance. All that POS dual system is, is a round chamber, with 2 exhaust outlets.
