engine wiggle
engine wiggle
Does everyone have a little engine wiggle or is it just me. I havn't got time to check it out now but everything seems to be tight.
RE: engine wiggle
Use some lock tight Check the screws that hold the engine mounting plate to the Aluminum Joint Bars and also check the screws that are on the side of the TVP side plates that hold the Aluminum Joint Bars....I had the same problem i did that and i'v had no other problems with it. Hope that helps
