Oily, greasy, grimey, fuel soaked fuse repair.
My plane took a hit from the ground last weekend and it seems the fuse can be repaired. It is broken in half, but I stripped the monocoat off, epoxied the fuse back together and added a new bulkhead. This is a well used plane and the monocoat was already lifted in multiple areas to which the two stroke exhaust fuel oil soaked into the wooden frame.
So my question is this, I don't want to recover the fuse with monocoat because I just don't believe I can get it to stick, but what I'd like to do is paint the fuse.
Is there any heavy duty, cover-all, fuel proof, BBQ, bullet proof type of paint out there that I can paint this fuse, and get it up in the air again?
If anyone has any experience with this please let me know.
Thanks.
signed,
Cheap-Skate Wanna-Do-It-Quick Plane Repairer.
Thanks.
signed,
RE: Oily, greasy, grimey, fuel soaked fuse repair.
If it's broken in half, fuel saturated, held together by bubble gum and bailing wire, etc... It doesn't really matter. Paint it with a pleasing color with Testors or something similar and whack clear PolyU over it and have fun. It's not gonna last long anyway.
I agree with SMUGator. NO paint will stick to an oily surface. You can try soaking the area with K2R Spot Remover several times, but I don't think that will help much. You might think about just trashing it, considering all the work you'll have to do to get some type of covering/paint to stick.
Dr.1
Dr.1
My Feedback: (8)
Dr1 is right... K2R spot lifter should be applied (and brushed off) as many times as necessary.... Don't SOAK the balsa with the spot lifter... it needs to gas off and let the powder absorb the oil/fuel....You have to be patient and let the product work.... It may take as many as 5 "treatments" but you can truly bring and old fuselage back from the dead (damaged???)...
Funny thing, you can't find K2R everywhere... not sure why.. must be a "what happens if you sniff this????" question....
I've used this trick for years with many good results...
Deadstik...
Deadstik...
OH
Take everything out of the fuse.(radio gear engine tank) Fill it with and bury it in kitty litter, and leave it for about a week. After that it should be pretty much fuel free. I had a fuel tank split filling the fuse with fuel, and this is what I was told to do, and it worked.
Bob
Bob
You can also use corn starch. Sprinkle it on, rub it in, let sit for a couple of hours and brush off. You will need to repeat this several times.
I also suggest coating/painting the area with SIG "StixIt", then recover. The StixIt has extreme holding power, much better than Balsarite. On fresh wood, the wood is going to separate before the covering comes loose. I have not tried StixIt under paint.
To remove covering applied over StixIt, you MUST apply heat to soften the StixIt while you are removing the covering.
